This repair was posted about another car.
"1. If a replacement steering gear is being installed, carefully grasp steering gear shaft and rotate until steering gear is in full left turn position. Rotate steering gear shaft back from full left turn position until master spline on steering gear shaft is aligned with master spline on steering gear coupling. With master spline aligned, attach steering gear to steering gear coupling. 2. If original steering gear is being installed, align mark on steering gear shaft with mark on steering gear coupling. With marks aligned, attach steering gear to steering gear coupling."
We are at this point. When we put the key into lock position the steering wheel is locking upside down. What do we need to adjust to get the steering wheel to lock upright?
SPONSORED LINKS
Sunday, October 4th, 2009 AT 1:43 PM
