1996 Chrysler Concorde P600 code
128,200 MILES • 6 CYL • FWD • AUTOMATIC
BIGROB1
I'm getting a p600 code for my car I can drive fine when I get a few miles it like it idleing high. When I turn the car off it run find for a short time. How can I fix thie problem.
Nov 3, 2009 at 1:30 PM
  • 31,937 POSTS
Hi there,
You should be getting a 4 digit P code Pxxxx, can you re check and advise please.
Mark (mhpautos)
Nov 3, 2009 at 3:08 PM
BIGROB1
code is P0600
Nov 4, 2009 at 11:32 AM
  • 31,937 POSTS
Hi there,
Code P0600 is a CAN bus malfunction, you will need to have the wiring and loom plugs checked for a fault and also the ECU can be faulty, you can have this removed & bench tested.
Mark (mhpautos)
Nov 4, 2009 at 12:45 PM
BIGROB1
Where is the EUC located so I can take it out to be tested?
Nov 4, 2009 at 12:50 PM
  • 31,937 POSTS
Hi there,
not sure, will have to look that up when i get onto Mitchell 1 later to day. i will post when i find out.
Mark (mhpautos)
Nov 4, 2009 at 1:10 PM
BIGROB1
ok thanks!
Nov 4, 2009 at 1:21 PM
  • 31,937 POSTS
See pic for location of PCM Mark (mhpautos)
https://images.2carpros.com/forum/automotive_pictures/61395_Noname_19.jpg
Nov 4, 2009 at 7:03 PM
