1996 Chrysler Concorde 1996 Chrysler Concorde Headlight Bul
162,000 MILES • 6 CYL • 2WD • AUTOMATIC
LORUSSOC
I have a headlight out and need to replace the bulb. I am trying to remove the mounting screws (at least the ones that I believe are th mounting screws), but they just spin. I tried pulling the screws out thinking that it was stripped but they are holding tight. Am I missing something? Little help please.
Dec 19, 2008 at 7:28 AM
  • 110,248 POSTS
Hi:
Are you sure you can't access the bulb from the back of the light assembly (under the hood)? Also, the screw you are removing, is it black and plastic?
Jan 22, 2009 at 9:09 AM
