1995 Chrysler Concorde stuck in second gear
125,000 MILES • 6 CYL • FWD • AUTOMATIC
MLEEDY
my trans stuck in second gear did some reseach and am tring to fix this problem. i have service tran filter and fluid and have replaced input sensor on trans. but before this happened no problems with trans before. it was low on fluids but i don t know if that could have cause problem. tried to drive it after do what i siad and it shifted from first to second and stuck again. checked engine code on car and check engine light flashed 332 and 55 can u help matt
Jan 4, 2009 at 4:51 AM
VIPERTEK
  • 40 POSTS
the trans is in "limp in" mode first thing u need to do is get trans codes . not just eng codes . if there is a "fault after shift code 51.52.53.54 or a gear ratio error code trans will need to be rebuilt. there is a seal failure or a broken component .I am a chrysler trans tech. all other codes will need diagnosis. in 1996 chrysler fixed problems with seals in the low reverse and 2-4 seals changed from "lipseal" to "D ring seals". that took care of most problems with 604 trans as well as your 42 le trans in your car
Jan 8, 2009 at 9:06 AM
