1995 Chrysler Concorde obd I scanner
CDJ1967
1995 Chrysler Concorde V6 Front Wheel Drive Automatic 168570 miles
can anyone tell me exactly where the sci conecter is to plug the code reader in, i cannot find it under the dash or hood, been told its under the hood on the drivers side, but find nothing
Nov 30, 2007 at 1:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f9ff34c433="cdj1967"]1995 Chrysler Concorde V6 Front Wheel Drive Automatic 168570 miles
can anyone tell me exactly where the sci conecter is to plug the code reader in, i cannot find it under the dash or hood, been told its under the hood on the drivers side, but find nothing[/quote:f9ff34c433]
If you r trying to access the codes on it
You can do so with out the scanner just cycle key on off three times read codes
And its not OBDII ready
So your not going to find the plug.
you have a semi square plug Under hood
Good luck
Nov 30, 2007 at 2:08 PM
