1995 Chrysler Concorde Engine stalls
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRESALAZ
Car will stall out periodically as I'm drivig down the highway. Sometimes it starts right up, and other times it will have to set a while before we can start it up again.
Any suggestions on what could be causing this?
Jan 1, 2009 at 1:26 PM
  • 110,251 POSTS
Hi:
If there is no check engine light coming on, I would start with checking fuel pump pressure. Most nationally recognized parts stores will lend or rent the gauge to you. Just hook it up to the fuel rail and see what kind of pressure you are getting.
Jan 22, 2009 at 9:05 AM
