1995 Chrysler Concorde engine over heating
160,000 MILES • 6 CYL • FWD • AUTOMATIC
PETE1234
has a new water pump; thermastat-timing belt it blows coolant out of the expantion bottle has bleeder valve at the themastat -does it also needpurged at expantion tank radiator looks brand new no coolant in motor oil no exsessive white smoke on cold engine
Feb 3, 2008 at 5:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:5e94c49e98="pete1234"]Other Category problem
1995 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 160000 miles
has a new water pump; thermastat-timing belt it blows coolant out of the expantion bottle has bleeder valve at the themastat -does it also needpurged at expantion tank radiator looks brand new no coolant in motor oil no exsessive white smoke on cold engine[/quote:5e94c49e98]
You can make sure the system is air free
and also try a head gasket test kit
Feb 11, 2008 at 1:49 PM
