The car starts just fine and after running about ten minutes it dies and won't start again for awhile. any idea's what might cause this?
Mar 25, 2008 at 7:23 AM
JDL
✓Experienced Mechanic
If your not sure what the problem is, go with the basics. Check for trouble codes, if the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, check the fuel system. You have to do the testing when the vehicle refuses to start.
