1995 Chrysler Concorde codes
1995 CHRYSLER CONCORDE
93,644 MILES • 6 CYL • 2WD • AUTOMATIC
LONEWOLF1218
I just bought this car last week and it is acting up.It started stalling on me and now wont start.Turns over no spark.I did the onboard code search,ie turn ignition on off 3 times.The blinking check engine light gave me the code,125455.I did this several times it came up the same.I think it might be the crankshaft position sensor.Any ideas?I am trying to save money by doing it myself.If this is the problem,how do I access the sensor?From the top or the bottom of the car?
May 28, 2010 at 2:00 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 28, 2010 at 4:59 PM
LONEWOLF1218
I just finished working on this car.As I stated before It would crank over but no spark.I did the code search by on/off key 3 times.The code I got was 125455.Now I had a mechanic over,we changed the crankshaft position sensor,changed the ignition coil,wires and plugs,and checked the voltage on the camshaft sensor.I am still getting no spark.He told me it was the computer that went bad.Is this what happens when there is no spark and changed what the code called for?
May 30, 2010 at 2:05 PM
