1995 Chrysler Concorde 1995 Concorde - Engine starts for 2-
120,000 MILES • 6 CYL • FWD • AUTOMATIC
CONCORDE_BLUES
After cranking the engine starts but only briefly and then stops. What would cause this?
I have noticed: the blower is stuck in the high position and the power locks do not work.
I have checked the battery and all of the fuses and these are fine. The cables to the throttle are fine. I have removed the fuse for the blower so I could hear the fuel pump when placing the key in the start position.
I am thinking that maybe the car has a security system. Tried using the key on the passenger door but this did not work. I am stumped as there is little information about security systems online - at least I cannot find it. I appreciate the help!
Jan 21, 2008 at 5:04 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it may have to go to a shop to be scanned.The Body Control Module needs to be scanned for codes, might be why th edoor locks dont work or vice-versa. Try unlocking passenger door with ignition off and all doors closed
Jan 21, 2008 at 11:46 PM
CONCORDE_BLUES
Yes, I tried the passenger side door unlock with the key; also uninstalled the keyless remote entry under the dash - but to no avail.
Thanks for the reassurance - I like to try to fiux these myself but with the computers nowadays... Well you know. Thanks again, two truck is enroute. ;o)
Jan 22, 2008 at 3:01 AM
