1995 Chrysler Concorde
LENSTERZ
  • 1995 CHRYSLER CONCORDE
Steering problem
1995 Chrysler Concorde 6 cyl Two Wheel Drive Automatic
whats the best way to change the inner tie rod end bushings the haynes manual doesn't explain how to do it
Saturday, November 6th, 2010 AT 9:09 PM
CARADIODOC
  • 33,916 POSTS
I don't think you can buy just the bushings. They are a very low failure item so you might consider salvage yard parts. If your steering wheel is straight now when driving straight ahead, you can replace just one link and adjust it until the steering wheel is straight again, then replace the other one if necessary and do the same thing. That will put total toe back very close to where it was for good tire wear. It still would be smart to have an alignment done. If you don't, keep an eye out for signs of feather-edging on the inside or outside edges of the tires.
Caradiodoc
Saturday, November 13th, 2010 AT 4:26 AM
