1994 Chrysler Concorde too much cranking before engine will
1994 CHRYSLER CONCORDE
T.J.HAWKINS
1994 Chrysler Concorde 6 cyl Front Wheel Drive Automatic 248 km miles
Been a great car
love 3.3 engines
All of a sudden the engine has to crank over many times and the gas pedal has to be right to the floor inorder to get it started. Also can smell gas.
Can you help us,
Thanks Tammy
Jul 9, 2010 at 12:51 AM
LEGITIMATE007
  • 5,121 POSTS
high tammy, I think your engine is flooding, because of a bad fuel pressure sensor or a leaking injector. you will need to have it tested, one quick way to see if the fuel pressure regulator is leaking or bad , is to pull the vacuum hose off of the sensor, and see if it leaks. otherwise it will need to be pressure tested
Aug 6, 2010 at 3:00 PM
