1994 Chrysler Concorde remove wheel and all
1994 CHRYSLER CONCORDE
165,000 MILES • 6 CYL • FWD • AUTOMATIC
SDCARTER95
can i remove nut in center of wheel, to take off the whole wheel and brake and rotorter at the same time? remove the 4 of the 5 lug nuts. the fifth one got damage,
Jul 19, 2009 at 1:14 PM
DANAUTHIER
  • 156 POSTS
No, I am sorry to tell you that will not work. The brake assmblies are connected to knuckle and the hub & bearing which is connedted to the lower control arm and strut asm. Your best bet is find someone who could remove the damaged lug nut for you with out damaging the wheel. There are took kits designed to do this.
Jul 19, 2009 at 1:31 PM
BUDDYCRAIGG
  • 2,262 POSTS
probably not.
you cant take the rotor off, until the caliper is off.
you cant take the caliper off cause the wheel is in the way.
I'll be right back with a tool that may help.
Jul 19, 2009 at 1:35 PM
BUDDYCRAIGG
  • 2,262 POSTS
They are made for taking off the locking lug nuts when you loose the key.
I think i bought the pair that i have from Oreilly's for about $30.
Jul 19, 2009 at 1:38 PM
