1994 Chrysler Concorde radiator fan
MRPIOTR
Engine Cooling problem
1994 Chrysler Concorde 6 cyl Two Wheel Drive Automatic
i ve 94 cancord and no metter the engine is cold or hot the radiator fan is working on hi all the time ac is off have any idea what my be the problem
Oct 29, 2008 at 4:31 PM
  • 110,248 POSTS
Hi:
Check the temp sending unit and the fan relay. My guess is the relay. If there is another one identical in the relay block, switch the and see if it helps.
Nov 5, 2008 at 9:07 AM
