1994 Chrysler Concorde leaking coolant
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
WINDSHIELDWILLIE
Concorde is leaking coolant when I shut engine off. I think it is a softplug. Will this hurt the engine if I keep driving it, as long as I keep fluid in it?
Aug 31, 2008 at 2:45 PM
  • 31,937 POSTS
Hi there,
If you keep the coolant up no problems, but you run the risk of the leak blowing out and causing a real problem don't mess about get it fixed and then you will be safe from a real expensive repair.
Mark (mhpautos)
Aug 31, 2008 at 3:22 PM
