1994 Chrysler Concorde hot
10,000 MILES • 6 CYL • FWD • AUTOMATIC
DANA1954
the car shuts off when it gets to heat driving then starts back up when it cools down
Mar 30, 2010 at 10:53 AM
JERRYGOODWRENCH
  • 77 POSTS
Check fuel pump or possible bad fuel injector that is out of range and shuts down the computer injector pulse. Check each injectors ohm reading with injector unplugged.Shoud read around 11 or 12 ohms.If you find one that is way out of range then you have possibly found the culprit. good luck.
Apr 24, 2010 at 10:58 PM
