1994 Chrysler Concorde HELP please!!
KGALLAGHER
Engine Mechanical problem
1994 Chrysler Concorde 6 cyl Two Wheel Drive Automatic
Okay our 94' chrysler concorde shuts up while drivng, we will be driving down the street and it just shuts off and then sometimes it will start up again and then sometimes it wont. We have the the ignition switch replaced, the fuel filter and the fuel pump replaced and it still does it??? what could it be, we are running out of money and ideas..please help.
Jun 10, 2010 at 11:22 AM
  • 75,988 POSTS
Check the fuel pressure if it's within specs. and comeback with the readings.
Jun 10, 2010 at 4:04 PM
KGALLAGHER
[quote:03c908fc27="rasmataz"]Check the fuel pressure if it's within specs. and comeback with the readings.[/quote:03c908fc27]
How do you check the fuel pressure? and what if the fuel pressure is bad..then what do we do?????
Jun 11, 2010 at 11:26 AM
  • 75,988 POSTS
If the pressure is not within specs the fuel pump has to go though its new and also are the injectors pulsing-both okay
Could be very well be the ASD relay or the computer itself
Jun 11, 2010 at 11:51 AM
KGALLAGHER
the relays have been changed....and also a new coil was put it as well as fuel injector cleaner and its still stalling!!!!!!!!!!!!!!!!!!!!!!!!
Jun 15, 2010 at 1:21 PM
