1994 Chrysler Concorde car stumbles
1994 CHRYSLER CONCORDE
RANDY4U45
Heater problem
1994 Chrysler Concorde Front Wheel Drive Automatic 133000 miles
Hi, my 1994 concorde drives great for the 1st 5 minutes I turn it on. It then stumbles on freeway speeds but will keep going if I barely press the gas pedal. It has now started to die at times but will start right back up after a few minutes. It sputters in the motor if I try top gas it hard when it is starving for fuel or whatever is wrong. Crank position sensor? Fuel pump?
Oct 14, 2009 at 10:23 AM
CH112063
  • 1,320 POSTS
You have to check it for proper fuel pressure and electrical sensor problems, it could be quite a few things. The fuel pumps were problem parts.
Oct 15, 2009 at 9:01 AM
