1994 Chrysler Concorde A/C Relay code
209,000 MILES • 6 CYL • FWD • AUTOMATIC
MUSICMAN1961
I've just replaced the compressor. When I start the car and turn on the A/C nothing happens it just blows hot air and I don't hear the A/C clucth engage. When I check the computer codes I get a 33 which is the A/C Relay. Where is the relay?
Jul 7, 2008 at 6:52 AM
BMRFIXIT
  • 19,053 POSTS
clear the codes and run the ac system again
if you had the codes stored in from before it will enable the ac system and will not work
I would clear the codes 1st and give it a try
good luck
Jul 10, 2008 at 10:21 PM
