1993 Chrysler Concorde 1993 concorde shifting and starter
CAROLEE
1993 Chrysler Concorde Front Wheel Drive Automatic
when i go to start the engine if the dummy lights and fuel guage don't come on the engine will still start but going down the road it won't shift out of 1st gear. everything works great if all the lights come on, once in a while it will go off (not the engine but the guages will shut off) going down the road and the whole car will buck and it will shift down to 1st gear.
i can keep turning the key and sometimes, when it wants to, the guages will come on and it works fine, but it's getting worse.
Mar 22, 2010 at 4:18 PM
CARADIODOC
  • 34,400 POSTS
Lok at the ignition switch and the electrical connector. The switch contacts can become overheated and burned causing an intermittent connection. The terminals in the connector can overheat and melt the plastic body.
caradiodoc
Mar 22, 2010 at 4:51 PM
