1993 Chrysler Concorde
RMM9
  • 1993 CHRYSLER CONCORDE
Transmission problem
1993 Chrysler Concorde 6 cyl Front Wheel Drive Automatic
knocking noise when I put car in reverse but not in any other gera but stops after about 10 minutes when I put it in reverse. Just does this in the morning
Monday, September 14th, 2009 AT 10:47 PM
  • 109,885 POSTS
Check to see if there is a broken motor mount or something loose. Is the engine running smooth when this happens?
Friday, September 18th, 2009 AT 7:30 PM
RMM9
Yes the engine is running smooth it just knocks when I put it in reverse. Like I said befor. It runs great after I drive it does not make it in any other gear just reverse in the morning .
It will no longer make this noise after first started in the morning and after the first 10 min I can put it in reverse again and any other gear it will nit do it any more the engine runs great. If I go straight to any gear other than reverse when I start the car other than rverse it soe not make this noise
randy
Friday, September 18th, 2009 AT 11:17 PM
