Shut out in the cold 2000 Cirrus Rear Door Latch
OLDDRUM1
  • 21 POSTS
2000 Cirrus/Stratus v6 Auto 4 Door 189000 miles
Rear door would not open from inside, now will not open from outside and inside. Child proof saftey is off. Outside handle sticks out a little. Door will not open with outside or inside latch. Not locked should open. How do you get to the mechinism with door in closed postion? Has electric locks and windows.
Sep 13, 2007 at 1:50 AM
2CARPRO JACK
  • 11,533 POSTS
You have to start removing panels til you have access.If the rear seat is in the way remove it,botom usually just pulls up kinda hard to pop out.There will be a few screws holding the panel on, but mostly they just snap on with plastic retainers
Sep 17, 2007 at 12:53 AM
