2000 Chrysler Cirrus Turning lights
2000 CHRYSLER CIRRUS
71SAXMAN
Electrical problem
2000 Chrysler Cirrus 4 cyl Front Wheel Drive Automatic
My turning lights have quit working. I have changed the flasher and the unit and still no ticking no anything. What else could I try?
Apr 21, 2008 at 10:12 PM
MOPARNUT1393
  • 34 POSTS
[quote:9a70bad181="71saxman"]Electrical problem
My turning lights have quit working. I have changed the flasher and the unit and still no ticking no anything. What else could I try?[/quote:9a70bad181]
check the fuse first, then try using the signal....
if no lights come on try pulling the blinker switch arm a little like if you were to turn to the bright lights rock it back and forth may have a bad turn signal switch. if you decide to take the switch out of the steering wheel do so carefully and make shure battery is disconnected or the air bag may deploy! if you have very little mechanical knowledge please take to a shop for diagnosis.
Apr 21, 2008 at 10:20 PM
