2000 Chrysler Cirrus turbine speed sensor
138,000 MILES • 6 CYL • FWD • AUTOMATIC
LJOHNSTOY
How do you replace this sensor and where is it located.
Apr 27, 2009 at 12:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, You will need a Wrench and/or a Deep Well Socket. You can determine size when you purchase the part. And I would recommend replacing them both they should be less than $35 for both. The Turbine Speed Sensor may also be call an Input Speed Sensor the other will be the Output Speed Sensor. Below is the locations....
https://images.2carpros.com/forum/automotive_pictures/188069_00cirrusspeedsensors_1.jpg
Apr 27, 2009 at 12:40 PM
LJOHNSTOY
.[/quote:bac649e3c7] Thanks for the diagram. I have already replace the output sensor but did not know where the input sensor was. Once again THANKS ALOT
Apr 27, 2009 at 1:09 PM
