2000 Chrysler Cirrus transmission screen
JACK DOE
Transmission problem
2000 Chrysler Cirrus 4 cyl Front Wheel Drive Automatic
how do i replace my transmission screen on a 2000 cirrus. It seens to go in and out of gear and i was thinking it could be my transmission screen.
Dec 16, 2009 at 1:18 PM
CH112063
  • 1,320 POSTS
hello, its fluid screen is called a filter, its location is on a part called a valve body, if you remove the trans. oil pan, you'll see it, what you need is called a transmission service, i am glad your looking at first things first, good luck.
Jan 5, 2010 at 10:36 AM
