2000 Chrysler Cirrus leaking transmission pan gasket
85,267 MILES • 6 CYL • FWD • AUTOMATIC
FIREFIGHTER64
Hi
I had a new transmission pan gasket put on last week, and it is leaking again, now I am told I need a new pan, can this be so/
Thank You
Ben
Oct 18, 2010 at 6:43 AM
SATURNTECH9
  • 30,869 POSTS
It could be possible but i would hope they would have seen the pan issue when they changed the gasket.Did you come and have the gasket replaced because it was leaking?
Oct 18, 2010 at 6:54 AM
FIREFIGHTER64
Hi
Yes the pan gasket was leaking.
Oct 18, 2010 at 8:37 AM
SATURNTECH9
  • 30,869 POSTS
The only way the pan usually leak's is if it hit's something and get's bent.
Oct 18, 2010 at 12:37 PM
