2000 Chrysler Cirrus Coil
CBMAN3
Electrical problem
I get power to the coil and it ends there.I replaced the coil twice and still no spark,Please Help. THANKS millercbman@frontiernet.net
Jun 21, 2009 at 2:28 AM
JDL
  • 16,098 POSTS
Hello, Not sure of litre size? There are distributor issues with some of these systems. I can't tell you to replace distributor without being sure, I can't be sure from here. If the asd relay is supplying voltage to everything it should, with the engine cranking, check for b+ to the injectors. Next, I'd suspect something with the distributor/ circuits.
Jun 21, 2009 at 3:21 AM
