2000 Chrysler Cirrus Brake Light Bulbs Replace
2000 CHRYSLER CIRRUS
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANOWDMI
I need to replace the tail light bulbs. I unscrewed the unit from the body and was faced with one square port with wires in it and then 3 quarter turn caps. I just need to know how to open it up to replace the bulb.
Mar 31, 2010 at 5:18 AM
CH112063
  • 1,320 POSTS
The square one twists a quarter turn also then pulls out. They get stuck and don't always come out that easy but they usually all turn counter clockwise and pull straight out. Spray the plastic with silicone and the next replacement will be easier. Use a pair of pliers for more power. ok Take a good look to see if their are any locking clips that must be pryed slightly. Even if they break, it stays put.
Apr 9, 2010 at 1:12 PM
