2000 Chrysler Cirrus
2000 CHRYSLER CIRRUS
MZEBABE52
Engine Performance problem
2000 Chrysler Cirrus 6 cyl Automatic 197000 miles
Im haveing starting problems with my car. It trys 2 start but wont @ times. But when it starts after a slow start an driving awhile it drives fine. but when I turn it off the problem starts again. Would that b a fuel pump fuel filter starter alternator? R could it b something else. Ive had the distributor changed. Im @ a loss.
Mar 24, 2008 at 3:29 AM
BMRFIXIT
  • 19,053 POSTS
check and make sure the distributor was installed and timed correct
check the battery also you need to do fuel pressure test and injector leak test
Mar 27, 2008 at 1:36 PM
