1999 Chrysler Cirrus rpm dropping @ stop in gear
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
GDADDYB
I notice that when at a stop while in gear, my rpms will drop down to the first line (500?) and the oil light will come on. The engine acts like it wants to die but doesn't.
also, I've had a mechanic check it out and put it on the diagnostic scanner they have. No codes came back. Notice that this only happens once the car has warmed up to the max safe temp..
Feb 18, 2009 at 7:53 AM
ZACKMAN
  • 4,202 POSTS
Have your mechanic check for vacuum leak. I would also look at your EGR system for leak.
Feb 19, 2009 at 4:58 PM
