1999 Chrysler Cirrus no fuel getting to engine
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
SERE32003
I have a 99 chrysler cirrus that was parked on a hill with little gas in it when I went to start it , it would only crank not start. I pushed it to level ground and it still only crank no start. I took of the air filter assembly and sprayed gas into the intake, the car will start but only tell the little fuel I sprayed in the intake is gone. I do not know where the fuel line comes in so I am unable to take it off to see if the pump is working I need help please can not afford to take it to a shop.
Oct 18, 2009 at 7:39 AM
JDL
  • 16,098 POSTS
welcome to the forum, Did you put any gas in it? Use a gage and check fuel pressure. With key on, no crank, can you hear the pump run for a couple seconds? The fuel pump relay is in the power distribution center under the hood. If you use a jumper wire on the two terminals for the switch side of relay, the pump should run?
Oct 18, 2009 at 8:10 AM
