1999 Chrysler Cirrus HOW TO !
OVI_MOV
Electrical problem
1999 Chrysler Cirrus 6 cyl Two Wheel Drive Automatic
How to change the battery?
Jan 19, 2009 at 7:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ensure keys are out of the ignition.
Remove any braces, if necessary, that may be holding battery in place.
Disconnect the ground wire (black) from battery terminal, then insulate the end of wire with electrical tape for protection until installing new battery.
Disconnect the hot wire (red) from battery terminal and insulate same as ground wire for protection.
Remove battery from vehicle.
Install new battery with reverse procedures.
Thanks for using 2CarPros.com!
Jan 19, 2009 at 9:14 AM
OVI_MOV
how to get to the battery?
where is it?
Jan 19, 2009 at 11:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your battery is located in the front left wheel well in its own little compartment. I suggest you remove the front left wheel for easier access. There is a plastic access panel that must be removed before the battery can be disconnected and removed. It is very different location then most vehicles.
Jan 19, 2009 at 11:56 AM
