1999 Chrysler Cirrus HEATER
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
RALPH.BIAS
NO HOT AIR COMING OUT WHEN HEATER IS TURNED ON, I HAVE MADE SURE THERE IS A
THERMOSTAT [REPLACED IT] WITH NEW ONE
HAVE MADE SURE CORE IS NOT CLOGGED,
PLEASE HELP ME FIGURE THIS ONE OUT!
Oct 8, 2009 at 12:56 PM
  • 75,988 POSTS
Check if it has a heater control valve if so check it. Could also be a problem with the air mix/blend/mode/recirc door problems to include vacuum, actuator and HVAC control module-
Oct 8, 2009 at 1:01 PM
