1999 Chrysler Cirrus heat blows hot for a second then cold
110,000 MILES • 6 CYL • FWD • AUTOMATIC
BDOOGAN
once the car warms up i turn the heat on and its warm for about a minute or two and then it gets cold. If i turn it off for about 10 min and then back on it will be hot again for a minute or two. Do you know what the problem might be?
Dec 10, 2009 at 3:55 PM
BLACKOP555
  • 10,386 POSTS
i would really be leaning towards a issue with a plugged up heater core. to test feel the hoses when the air is warm. and then when its cold feel them. do you note a temperature change/
hoses i am refering to are the heater core hoses. they are about inch diameter and they run through the firewal to the heater core.
Dec 11, 2009 at 5:59 AM
