Well this is a subjective question?
Warm enough as in quality or quantity?
If it is hot but only blows in low speed, it is the blower motor Resistor pack found elsewhere on this forum!
The only thing left is the hot/cold air control switch located in the center of the dash.
The bezel cover (pries) pops right out.
then there is about 7 phillips head screws Below the Radio holding everything in place.
You must move the botton black light tray down and to the right and out of the way to pull the control switch down and flip it over to view!
If the cold hot lever has come loose check to make the cable tabs are connected and tight!
I had just the opposite problem down here in Florida, would not get cold enough and it was the cable control switch!
Your worst night mare= A Bad control switch!
Bob
Nov 15, 2008 at 4:35 AM
