1999 Chrysler Cirrus Alternator Belt replacement
GBEEHLER
Engine Mechanical problem
1999 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
What is the trick to removing the Power Steering Pump Drive Belt so that I can get to the Alternator Drive Belt.
I have loosened both Bolts on the Pump Mounting Bracket but can not get it to rotate to the loosen position.
Help!
Mar 8, 2009 at 8:53 AM
ZACKMAN
  • 4,202 POSTS
There are 3 bolts. 2 just behind the pulley, and the other one is on the back side of the bracket. Once all 3 are loosened, locate the square hole located in between the two bolts behind the pulley. Use 1/2" ratchet or breaker bar to move the pump.
Mar 8, 2009 at 5:00 PM
