1998 Chrysler Cirrus water pump
124,876 MILES • 6 CYL • FWD • AUTOMATIC
JOSEPH A
how do i replace the water pump
Jan 15, 2010 at 12:19 PM
  • 75,988 POSTS
1.Drain cooling system. 2.Remove right engine mount and bracket. 3.Remove timing belt. 4.Remove water pump mounting bolts. Water Pump - 2.5L Engine
https://images.2carpros.com/forum/automotive_pictures/12900_cwp1_1.gif
Water Pump Inlet Tube
https://images.2carpros.com/forum/automotive_pictures/12900_cwp2_1.gif
5.Separate pump from water inlet pipe and remove pump. INSTALLATION 1.Clean all gasket and O-ring surfaces on pump and water pipe inlet tube. Water Pipe O-Ring
https://images.2carpros.com/forum/automotive_pictures/12900_cwp3_1.gif
2.Install new O-ring on water inlet pipe. Wet the O-ring with water to facilitate assembly. CAUTION: Keep the O-ring free of oil or grease. 3.Install new gasket on water pump and install pump inlet opening over water pipe, press assembly to cause water pipe insertion into pump housing. 4.Install pump to block mounting bolts and tighten to 27 Nm (20 ft. lbs.) . 5.Install timing belt and right engine mount bracket and mount. 6.Fill cooling system. 7.Install accessory drive belts.
Jan 15, 2010 at 12:37 PM
