1998 Chrysler Cirrus
MAMASCAR
Engine Cooling problem
1998 Chrysler Cirrus 6 cyl
i need to add antifreez, how do I get some of the water out of the radiator
Nov 14, 2008 at 6:29 AM
ZACKMAN
  • 4,202 POSTS
Remove passenger side fog light, remove mounting fastener and swing horn out of the way. You may need to unplug the horn wiring harness. Use a 3" 3/8 drive extension, 19mm socket with a universal joint. Attach the 19mm socket into the drain petcock (bottom right of the radiator) and loosen almost all the way out.
Nov 14, 2008 at 2:37 PM
