1997 Chrysler Cirrus timing belt tension
1997 CHRYSLER CIRRUS
80,000 MILES • 6 CYL • FWD • AUTOMATIC
MRREDD948
i have done everything to install timing belt according to the manual and advice from mechanics. However, I am not sure if I have done it correctly since the crankshaft rotation moves the tension pulley bracket away from the tensioner piston on the tensioner, in an up/down motion as the crankshaft is rotated. When it comes back down against the tensioner piston the crankshaft is no longer at tdc. Is the tensioner pulley supposed to move once it has been torqued? the belt broke when a friend of my daughter attempted to replace the water pump and incorrectly replaced the timing belt.
Dec 16, 2007 at 1:00 AM
2CARPRO JACK
  • 11,533 POSTS
According to Mitchell the TDC needs to be 3 teeth before for belt installation.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Great pics and full instructions. Did you have a hard time compressing the tensioner? sometimes they lose their ability to hold the belt tight
Dec 16, 2007 at 11:45 PM
