1997 Chrysler Cirrus repaired a broken Bolt pin for brake c
SPECIAL K
  • 1997 CHRYSLER CIRRUS
  • 6 CYL
  • FWD
  • 89,574 MILES
Just got done replacing bolt pin on a 97 Chrysler Cirrus along with brake pads. But on test drive still makes a sound only in drive not when using brakes. How do you see if the caliper is bad. Or rotor warped?
Saturday, September 26th, 2009 AT 8:15 AM
  • 109,885 POSTS
Can you describe the noise? As far as the caliper, if it sticking, you should be able to notice it. Also, if the rotor is warped, it would pulsate when you hit the brakes.
Please describe what is happening so I can better help you.
Tuesday, October 20th, 2009 AT 8:08 AM
