1997 Chrysler Cirrus radio wont work!!!! HELP MUSIC LOVER!!
1997 CHRYSLER CIRRUS
162,400 MILES • 4 CYL • FWD • AUTOMATIC
T3H_DOC.
To start, this is my 2nd car and I'm quite sure I know how to install an aftermarket deck.... on top of that I have helped many friends install their radios with no problem. So, you could understand my worry when I went to install my radio and it didn't work. I got most of the wires hooked up but couldn't find a ground wire. I did research and found out there isn't one and I had to attach it to a screw. I also checked every single fuse in that car a billion times. All are good. So just to recap, I have all fuses working and all radio wires connected to the proper wires coming from the car, and yet my radio still wont work or turn on or anything!!!
Oct 10, 2008 at 9:25 AM
ZACKMAN
  • 4,202 POSTS
Unplug the connectors. Use jumper wires to connect orange (constant) and red (switched) to battery, and black obviously to ground. Make sure the deck turns on. If it turns on, use multimeter to check power to the connectors.
You did not mention, but Cloud cars (Stratus, Cirrus & Breeze) have to have the antenna plugged in for the radio to work.
Oct 10, 2008 at 11:28 PM
T3H_DOC.
wow thank you so so much it worked like a charm but now i have another problem ....when i bought the car i listened to the radio and all 4 speakers worked and now that i installed my subs and cd player now only 2 work??? help please
Oct 11, 2008 at 10:49 AM
