1997 Chrysler Cirrus Power steering only works when acceler
97,000 MILES • 6 CYL • FWD • AUTOMATIC
REXANDFOXY
My power steering only works when I have a some acceleration. Very hard to steer from stopped or slow cornering. Belt may be loose. How do you tighten the belt?
Apr 10, 2009 at 3:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like power steering is completely out.. steering is much easier with acceleration even without power steering so it would be hard to notice a loss of power steering while under acceleration. Inspect power steering fluid. Also inspect pump to ensure bearings are not worn out. If OK and belt is loose tighten with the tensioner bolt.
Apr 10, 2009 at 3:49 PM
CARADIODOC
  • 34,413 POSTS
Try steering while stopped and in park. If there's no power assist, raise engine speed a little and you'll see the power assist come back. This is proof the pump needs to be replaced. It's a German-made "ZF" style pump with a remote-mounted reservoir. Common problem.
caradiodoc
Apr 18, 2009 at 5:32 PM
