HI MY CAR WILL CRANK BUT WILL NOT START. I DONT KNOW WHETHER ITS THE FUEL PUMP OR FUEL PUMP FUSE
Jun 25, 2008 at 7:34 AM
DJDANSFIFTYS
MEMBER
Find the fuse or relay and check that. If it is in working order, Try turning the ignition to on[not start] and listen for any clickilg sound. If you hear no sound, try tapping on the bottom of the gas tank. Not real hard. Some times that will get it going. If that works you will need to replace fuel pump
