1997 Chrysler Cirrus losing antifreeze
1997 CHRYSLER CIRRUS
180,000 MILES • 6 CYL • FWD • AUTOMATIC
DERE2664
losing antifreeze , but have heat, not over heating, not sure where to look for leak, would the water pump cause the problem , check engine light on too. if so , replacing water pump would i have to replace timing belt, would i have to put into time
Mar 7, 2010 at 5:16 AM
LEGITIMATE007
  • 5,121 POSTS
yes you wll have to replace the timing belt and set the timing, go to autozone and have them scan your vehicle for trouble codes and bring them back to me, I will look them up. also you could be loosing coolant in the combustion chamber, otherwise known as a blown head gasket.
Mar 7, 2010 at 5:22 AM
