1997 Chrysler Cirrus harmonic balancer removal
1997 CHRYSLER CIRRUS
PELIONCOWBOY
1997 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
How do you remove the harmonic balancer and keep it from turning at the same time?
Sep 13, 2009 at 5:39 PM
JOLENA2370
  • 14 POSTS
I have a few Ideas. Leave the belts on and try that if that don't work then you need a impact to remove the harmonic balancer. you also need a punch to loosen the sprocket for the timing belt or other wise you will brake the timing cover. If you have anymore questions please e-mail me back!
Nov 8, 2009 at 12:26 AM
