1997 Chrysler Cirrus fans
95,000 MILES • 4 CYL • FWD • AUTOMATIC
MATRAT419
my fans are not working at all, even when i turn the ac on. i am getting no heat in my car and my car overheated when i ran it too long. do you think it could be a fuse or a relay or what do you think?
Dec 23, 2008 at 5:09 AM
ZACKMAN
  • 4,202 POSTS
In your power distribution center under the hood, you need to check fuse #9 10A, #19 40A. Also in the same box, check the two cooling fan relays. Just swap the two with other relays, and see if they are working. ***Keep in mind, that they will only work if the car is at a high temperature***
If you are good in electrical, you may want to try bypassing the relay. Use jumper wires, and attach positive to green (low speed) and yellow (for high speed) and negative to black.
If all of them are OK, test your engine coolant temp sensor located on the thermostat housing.
Dec 23, 2008 at 11:43 AM
