1997 Chrysler Cirrus car battery
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DCAIN
How do I remove/replace the battery? It's in the wheel well.
Thanks
Jul 6, 2008 at 1:30 PM
SERVICE WRITER
  • 9,123 POSTS
I usually pull the wheel off and access it through the panel that sheilds it. Lossen the holeder and pull the calbes and it slides out okay...for a foolish location.
Jul 6, 2008 at 1:38 PM
RANDYD36
  • 14 POSTS
to remove the battery take off the left (drivers side) tire. then remover the battery cover/splash shield from the wheel well by turning the four plastic fasterners 1/4 turn counterclockwise. disconnect the negative battery cable first then the postive. remove the bolt and nut securing the battery strap and hold down bracket then remove them. if has weather package options disconnect the blanket heater electrical connector. install in reverse order
Aug 1, 2008 at 10:05 AM
