1997 Chrysler Cirrus alternator
1997 CHRYSLER CIRRUS
CLIMON69
  • 5 POSTS
Electrical problem
1997 Chrysler Cirrus 6 cyl Two Wheel Drive Automatic
how do i install an alternator and pulley?
Oct 23, 2010 at 12:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2831.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_751.jpg
Oct 23, 2010 at 1:03 PM
CLIMON69
  • 5 POSTS
how do i remove the belt to replace the belt that goes to the alternator?
Oct 24, 2010 at 5:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you can go through the right front wheel well if you remove wheel and fender lining. loosen the PS pump bolt 2 turns or so then loose the adjusting bolt on the PS bracket (should have curved slot). Remove the PS belt. Loose the idle bolt on the idler pulley (between alternator on top and AC compressor on bottom). Loosen the bolt in the middle of pulley. Slide the pulley toward front of vehicle and belt should come off.
Oct 26, 2010 at 8:55 AM
