1997 Chrysler Cirrus A/C Test and Troubleshooting
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVEJROY
A/C is blowing warm air. The Low end tests at 65 - 70 PSI which is high for the charts, I don't have a high end tester. Compressor is coming on? What, if anything do these symptoms tell you?
Jun 28, 2010 at 3:25 PM
  • 75,988 POSTS
Could be freezing up due to air and moisture forming into ice and blocking off the orifice tube-Get vacuumed and see what happens
Jun 28, 2010 at 4:05 PM
