1997 Chrysler Cirrus
AMANDA728
  • 1997 CHRYSLER CIRRUS
Air Conditioning problem
1997 Chrysler Cirrus 6 cyl Front Wheel Drive
i went to recharge the ac and I noticed there is no air coming from the vents only from the defrost and the floor can u help me because I cant figure out whats wrong?
Thursday, August 20th, 2009 AT 3:19 PM
  • 109,885 POSTS
The vents are actuated by vacuum. If it is only blowing from the defroster and floor, there must be a vacuum leak. Start by checking under the dash, the hood, and where the supply line goes through the firewall.
If you have the engine running, you may actually hear a hissing sound where the leak is.
Wednesday, September 2nd, 2009 AT 11:15 AM
